Drive shaft hitting gas tank
Old Aug 4, 2012 | 05:09 PM
jeffj's Avatar
Default Drive shaft hitting gas tank
I have a rock krawler 3.5 with a je reel 1350 drive shaft and just got under the jeep after doing the rubicon and at the u joint it was hitting the tank skid enough to dig into it about .25 inches. With my stock flange it hit just a little but it is bigger. When it is just sitting on level ground it looks like I have plenty of room. And also I have the 3 link in the back. Any help would be appreciated.
Old Aug 4, 2012 | 06:01 PM
wayoflife's Avatar
JK-Forum Founder
double check to make sure that your axle is centered? more than likely, you're off a bit and when flexing on the trail, your drive shaft swings over and hits your tank. i've seen this happen a lot.
Old Aug 4, 2012 | 06:04 PM
lanslide's Avatar
...this does not sound good
Old Aug 4, 2012 | 06:07 PM
jeffj's Avatar
Thanks a lot. I will check tomorrow.
Old Aug 5, 2012 | 11:18 AM
jeffj's Avatar
Just checked my rear axle and it was off about a .25 inches toward the gas tank. I moved the track bar two turns out and it looks like it is 1/8 of an inch the other way. It seems to drive all right. I thought it would be better to cheat it to the left a little sense I had that problem. Do you think this make sense and was that enough off to cause me to hit gas tank.
