Drive shaft problems
hi jeepers..
let me complecate the thread litilbit..
i have 07 jk 2doors with 32X11XR15 tiers
when i drive at 50 Mil/h and 75 Mil/h the jeep is shaking (but not very much)..
when i went to the dealer workshop they told me that the driveshaft is dameged and the alighnment numbers showed 1.47 degrees off (btw, they told me the acceptable number is 0-0.45 degrees) and they told me u should change the driveshaft..
is there any sort of repairing the driveshaft.??
you need to be more specific on what was off....camber? caster?
Unfortunately there is no real good way to repair the driveshaft. Your best bet is to change it out, but its a worthwhile fix/upgrade.
What exactly is wrong with the driveshaft? Are you sure its the driveshaft? There are a lot of things that can cause vibes.
hi jeepers..
am very sorry guys but the problem with the front axel as the guy at the dealer workshop said..
And that what making the shaking
There is a way to repare the axel or i have to change it ???
BTW/ i just install a 4" lift but the shaking was before a long time..
