drive shafts
Old Mar 18, 2012 | 01:39 PM
Bruski's Avatar
Default drive shafts
whelp now that i found my issue with my cv joint going bad I'm going to replace front drive shaft ........soooo I'm feeling a tom woods drive shafts .....
whats the opinions on these shafts
also I've read somethings about having todo adjustable control arms is this true?
i plan on doing this right the first time so lay it on me i need all info
Old Mar 18, 2012 | 01:42 PM
BALTHIS's Avatar
yeah im in the same boat but i broke mine haha snapped it in two, i was thinkin bout havn a cutom one made or gettin a a r.e. reel
Old Mar 18, 2012 | 01:50 PM
Bruski's Avatar
I see all good things about tom woods stuff and mixed opinions on reel stuff
Old Mar 18, 2012 | 02:45 PM
wayoflife's Avatar
JK-Forum Founder
if you're feeling a tom woods shaft is what you want, get it but, make sure to upgrade the u-joints to spicers or neapco. the joints they come standard with are cheap and i have seen them fail prematurely without any good cause or reason. you will not need to get adjustable control arms for the front shaft, only the rear.
yeah, fanboys can be pretty loud. don't know who would be giving you mixed opinons on reel especially being that they use made in the usa neapco u-joints. but hey, get whatever you feel like spending your money on.
Old Mar 18, 2012 | 03:08 PM
Bruski's Avatar
so are you saying some reels are nice hell i don't care who i buy i just want good stuff lol and ok so just rear do you have any you would recommend ? also thank you for being so helpful
Old Mar 18, 2012 | 03:16 PM
wayoflife's Avatar
JK-Forum Founder
any chance you could add in some punctuation? it sure would help me to read what you're trying to say.
so long as they're balanced well, drive shafts are for the most part, drive shafts. the biggest difference between one and the next are the components used to make them like the u-joints. some popular brands use cheap chinese u-joints of which i personally have seen fail enough times to concern me and really, for no good reason. it is for this reason i highly recommend that you either get a coast which comes with spicer u-joints or je reel, which comes with made in the usa neapco u-joints or, upgrade whatever shaft you get with either one of those u-joints.
regarding the rear shaft, are you asking about recommendations on control arms?
Old Mar 18, 2012 | 03:19 PM
Bruski's Avatar
sure i can do that ..
and ok so ill look into the j.e. reel . what control arms should i look at purchasing for the rear if i don't need them for the front?
Old Mar 18, 2012 | 03:26 PM
wayoflife's Avatar
JK-Forum Founder
LOL!! thanks.
any adjustable rear upper control arms should allow you to rotate your pinion up and in line with your rear drive shaft. this is a necessary step when running a u-joint style double cardan rear drive shaft. up front, you DO NOT want to do this as it will compromise your caster and that it an important part of good front end alignment. as far as control arm brands go, i have installed and run full-traction, teraflex, currie, JKS and a few others i can't think of off the top of my head and, they all were quality products.
Old Mar 18, 2012 | 03:38 PM
Bruski's Avatar
ok so sounds like I'm looking at a list as follows ..
1 .full traction ultimate rear upper control arms
2 .front and rear j.e. reel shafts ..
and i should be good to go ?
coming from a diesel world racing and pulling . jeeps a totally fun and new experience so much to learn
Old Mar 18, 2012 | 04:01 PM
Absolute's Avatar
I've seen to the contrary.
