driveshaft angle too much?
Old May 31, 2009 | 07:19 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Default driveshaft angle too much?
this is a pic of my front driveshaft at transfer case, I'm not sure if its to much of an angle now, I replaced my front springs last week with that same springs(original set bowed) It seems I got a lot more then 3in, I know my fronts were bowed before but these seem 2in higher or so. I now have a grinding/binding noise in 4wd coming from transfer case, just not sure if its because of the anlge or I killed transfer case
here is pic of the rear, almost no angle
Old May 31, 2009 | 07:35 AM
wayoflife's Avatar
JK-Forum Founder
yeah, that looks like you're about at your max on that CV joint. is the grinding kind of like a ratcheting sound? if so, it's the bearings in the CV joint going bad or are bad.
Old May 31, 2009 | 07:43 AM
tkob1060's Avatar
damn you hit the nail on the head, its definitely a ratcheting sound, so is it just the drive shaft then? or transfer case too? I cut the boot off yesterday because it was twisted really tight around the shaft.
Old May 31, 2009 | 08:08 AM
wayoflife's Avatar
JK-Forum Founder
it's just the drive shaft. replace it and you will be good to go
Old May 31, 2009 | 08:21 AM
tkob1060's Avatar
thanks Eddie
I got my 42k mi worth out of the stock with my 3in lift, I knew it would have to be done eventually lol, good to know its not the transfer case
Old May 31, 2009 | 09:06 AM
tkob1060's Avatar
hmm I wonder if I pull the 1in spacers that are in there will correct it for now. I want to goto a 6in long arm this year, I think if I get a new front now I'll need another longer one once I goto 6in lift right?
Old May 31, 2009 | 09:10 AM
wayoflife's Avatar
JK-Forum Founder
nope, if you are hearing the ratching now, your cv joint is toast and lowering your jk will not fix it. if you get a new shaft, you will be fine running it even after you go to 6" of lift.
Old May 31, 2009 | 09:12 AM
tkob1060's Avatar
ok awesome, thats even better news, I will order new shaft tomorrow
Old May 31, 2009 | 09:13 AM
doc307's Avatar
Get a new driveshaft and come to Durhamtown with us...
Old Aug 10, 2009 | 08:56 AM
RCJeeper's Avatar
TKOB, did u get a new driveshaft? Did it solve the problem? I think I have the same thing going on.
I replaced the DS with a Tom Woods about 2 weeks ago and I have the same sound. Kinda of spinning, whirling, rattling sound. It starts to make the sound around 40 mph and gets progressively louder.
At first I brought it to the dealer and they said it was the DS but replaced the tcase anyway. It went away for about a week or so then it's back. So I switched to a spare DS that I had bought as a spare some time ago. No sound, then about a week later its back. It was getting worse and worse so I decided that I had better get a aftermarket duel carden DS because of that extreme angle at the tcase like what you have pictured up above.
When I first started noticing it, I was trying to figure where it was coming from; transmission, t-case, front axle, driveshaft, rocks? I was going about 50 and switched into 4hi and the sound went completely away until I let off the gas and it came back. I demostrated that to the dealer and thats when they replaced the tcase.
The only time it was dead quiet was when I took off the front shaft for a couple of days waiting for the TW driveshaft.
I was under the Jeep one afternoon trying to figure this out and jiggled the output of the tcase to the front DS and there was a little up and down play. I figured that must be it but I went to the dealer this last weekend to look for a 300 for the wife and jumped under a couple of JK (6 to be exact) and 5 of them had the same up down play.
I didn't notice any special sounds until I added the 3/4 spacers to the 4" Superlift. Obviously the driveline angle has something to do with it.
