Driveshaft angles...?
Old Oct 26, 2010 | 05:08 PM
lobe50's Avatar
Thanks
So I take it that you are saying I should not spend the money on control arms at this point?
BTW, my caster reads 2.5 degrees. I plan on 35's soon, so I might want to get front lower arms right?? And set caster to around 6 degrees??
Also if you replace the rear driveshaft w/ an upgraded shaft, does that help alleviate the problem??
Thanks for the reply and Info !!!!!
