driveshaft noise?
I recently purchased a 2013 jk unlimited with a 4" skyjacker lift with adjustable lower control arms front and rear with 35" tires. Ride is unbelievably smooth on highway and over bumps. The only problem I am having is a mild noise when first accelerating. Sounds like when something is spinning and touches something. It only lasts about 2 seconds and doesn't happen all the time. It seems to only happen when on uphill incline and after driving for about 10 min. Any thoughts or suggestions? Thanks
Unfortunately, I can't provide you much help.. but I had a smiliar problem earlier this year when I bought my new stock JKU. 3k miles later, it hasn't made any noise again but when it did, it only happened on intial acceleration somewhere within 1-3k RPM. With my jeep sounded to me like the noise could have been either from the tranny, driveshaft, or transfer case.
I was deployed just shortly after I bought it so my girlfriend took it to the dealership for me and left it over night to get checked out. The next day when she went in the pick it up they told her it was normal
but I find that hard to believe.. So I'm curious to see what responses/help you get.. subscribed.
Ok you have a 4"lift crawl under the Jeep and check your boot on the front drive shaft and the small one at the transfer case for Grease flying out of it.if by chance the boot is torn remove the boot and clamps but not... not ...at the transfer case. Let us know. Good luck this is just a starting point
I've checked everything underneath. Boots are fine and there is nothing in contact with the driveshaft. If it were a pinion angle issue, wouldn't the noise be constant? Only happens after driving for a while and is very intermittent.
Thanks for all the help. Found a spot on the muffler where there could possibly be some contact with a heat shield when the muffler gets hot. Hopefully this was the problem. I will keep y'all posted.
Not a squeak. Feels more like metal on metal, but only lasts about 2-3 seconds when accelerating from stop but only happens after driving for a while and then is only intermittent. Hopefully it was the muffler rubbing the heat shield. Will know after driving it tomorrow.
