Driveshaft rub on Auto trans with aftermarket driveshaft?
Old 09-04-2012, 11:46 AM
69mach1's Avatar
Cool Driveshaft rub on Auto trans with aftermarket driveshaft?
Name:	RTI ramp at Pancake cmp.jpg
Name:	DS rub cmp.jpg
Name:	RTI ramp pancake 2 cmp.jpg
Anybody else having this problem? I'm getting lots of articulation but I see I'm rubbing the driveshaft to the auto tranny again thought I was done with that when I replaced the stock driveshaft.
I'm running a Teraflex 3" lift, 37" MTR's, Currie control arms upper & lower and a Coast driveshaft. Do I need a long arm kit to stop this from happening? or more bumpstop? or ?
I don't want to loose travel if I can help it , actually I want more travel if I can get it
Old 09-04-2012, 05:52 PM
Beau's Avatar
Did you trim or remove your skid for the trans. I am assuming that is what you are rubbing on.
Old 09-04-2012, 06:33 PM
69mach1's Avatar
Cool
Yes it's been trimmed but that is not where it is making contact. Side of the transmission/pan to driveshaft contact
Old 09-05-2012, 04:26 AM
rays0852's Avatar
Originally Posted by 69mach1
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=362285"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=362283"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=362284"/>
I can't see what mods you have, because I'm using the mobile app.
But if you keep treating that Sahara front axle like that you are on borrowed time my friend. 37s!?
I would worry more about beefing up that front end than how much flex I was getting. Can't comment on the front DS from experience.
My guess would be that your axle is not centered properly causing the DS to rub. Do you have a front adjustable TB?
Old 09-05-2012, 08:30 PM
69mach1's Avatar
Cool
Name:	Dana 44 truss 3 cmp.jpg
Name:	Dana 44 truss 5 cmp.jpg
It's a Rubicon Dana 44 5:13's, Elocker, trussed, C's twisted & braced, control arm skids, HD track bar & sway bar link mounts, Reid knuckles. JKS Adjustable track bar, axle centered. JKS sector shaft brace
I've added further track bar/stabilizer bracing since these pic's.
Curious what the folks with coil overs are doing regarding the driveshaft rub?
Old 09-06-2012, 04:38 AM
okie's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=362716"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=362717"/>
Hahahaha take that!
Sorry couldn't resist.
Old 09-06-2012, 11:15 AM
69mach1's Avatar
Cool
Originally Posted by mpkelley20
Holy beefed up axle. Very nice! I have no rub that I'm aware of with my RK 3.5" and coast drive shaft. Only thing I can think of is checking your axle for proper centering as mentioned above.
I painted my driveshaft so I could see if I dinged it or rubbed it and it's very clear I hit I think I'll offset the front diff a nudge to driver side as well as grind a little off the tab and pan at the tranny.
And thanks I couldn't help it either still appreciate inputs & viewpoints
Old 09-06-2012, 11:56 AM
taher2.1's Avatar
I have been having the same issue for a while so recently I decided to go with coast drive shaft - I am running 35 on three inch lift and trimming the skid plate will not solve the problem
Old 09-06-2012, 09:12 PM
rays0852's Avatar
Well knock me over with a feather......wth did you buy a Sahara for?
Nice setup.
Old 09-07-2012, 02:52 PM
69mach1's Avatar
I already have the Coast Driveshaft and I've already reworked and trimmed my factory skid plate for clearance. The driveshaft is hitting the auto tranny again just like the factory driveshaft did
Quick Reply: Driveshaft rub on Auto trans with aftermarket driveshaft?
