Driveshaft Selection??
Old Jan 12, 2010 | 05:20 PM
Rub61's Avatar
Default Driveshaft Selection??
Well I am going to replace my front driveshaft and have 2 choices. 1) buy the direct bolt up flange type and do the simplest install or 2) buy the driveshaft that require both the pinion and xfer case yoke assy. to adapt to the driveshaft. I currently have the 2.5" Teraflex spring lift with shocks on my 2008 2dr. Rubicon auto trans. The shafts I have been looking at are from JE Reel and I have no idea what would be the best option.
Thanks in advance
Old Jan 12, 2010 | 05:25 PM
blockrockin's Avatar
here is some info that might help.. i had the same questions.. i went with u-joint style shaft that uses yokes at the output shaft and pinion
https://www.jk-forum.com/forums/modified-jk-tech-2/drive-shafts-oem-flanges-cv-108305/
Old Jan 12, 2010 | 08:50 PM
Rub61's Avatar
Thanks for the reply. I kinda figured that getting rid of all the OEM and installing a new yoke assy. at pinion and Tcase would be the best bet. To bad just bolting to the original flanges isn't the best option since it would be much easier.
Old Jan 13, 2010 | 05:24 AM
Rub61's Avatar
I need to know if the D44 in my 08 Rubicon uses crush sleeve or shims to set the pinion preload.
I believe it uses the shims and I can just retorque the nut and not lose my preload. Anybody know for sure??
Old Jan 13, 2010 | 06:28 AM
Ronson's Avatar
My 07 has a crush sleeve.
Old Jan 13, 2010 | 12:23 PM
Rub61's Avatar
A crush sleeve sure does complicate the driveshaft intallation. I was hoping the D44's had the shims for pinion preload.
