Driveshaft Work
Old May 13, 2009 | 07:19 AM
tprice1985's Avatar
Default Driveshaft Work
Guys,
I saw a thread a while back that talked about cutting the cost of driveshafts and a member had said to have a local shop fab the driveshafts. I did a little reasearch and found that there is a shop in town that does killer driveshaft work. What do I need to have them do? I have a 2 door and would like to go with a 4" lift.
Old May 14, 2009 | 10:16 AM
tprice1985's Avatar
Default bump
Anyone......
Old May 14, 2009 | 01:17 PM
Bub's Avatar
Bub
Default Lift
Originally Posted by tprice1985
Anyone......
May not help but I installed the RC 2 1/2 spring and shock kit under some 2 inch spacers and although I don't need articulation there is no problem with extreme angle induced vibration and such. I posted some pics awhile back of the install and am real happy with the result. I looks and drives just like I want.
Old May 14, 2009 | 01:32 PM
NH4X4's Avatar
I would get the lift first and then drive the Jeep to the shop and let them no what size tires you are going to run too. They should no what to do...
Old May 14, 2009 | 05:22 PM
tprice1985's Avatar
Default Driveshaft
I will give that a try. Dont do alot of offroad but I know just as soon as I lift I will break I called the shop and they told me max $150
Old May 14, 2009 | 05:29 PM
capt scotty's Avatar
with a 2 dr and 4" lift you will need a new rear shaft. They can build it with shelf parts so it can be repaired easily with no custom parts. I would get the lift installed first. just make sure the installer of the lift adjusts your pinion agle correctly. My Local shop did a great job. Good Luck.
