dropping tcase down
Old Feb 18, 2012 | 09:01 AM
samhardy2008's Avatar
Default dropping tcase down
Sooo somebody was telling me that I could shim up my tcase in order to fix the pinion angle for front drive shaft....is this true??
Old Feb 18, 2012 | 09:08 AM
mkjeep's Avatar
Incorrect on the jk. On TJ's this is done by installing shims to drop the tcase and mostly for the rear ds angle. The jk tcase is not setup the same way. You need adj control arms to adjust pinion angle for castor in front, correct pinion angle in rear.
Old Feb 18, 2012 | 09:15 AM
mkjeep's Avatar
I looked at your profile, says you have the 4in superlift on a 4dr. Did you install the cambolts for the front? If so to get more castor adjustment you'll need to have your ca brackets fixed with a washer welded on and install front adj lower ca's. With the 4dr you really don't "need" to do anything with the rear until you change to an aftermarket driveshaft to correct pinion angle. I ran this kit for about a year.
Old Feb 18, 2012 | 03:18 PM
Was dealer installed :/....but no I know I need the adj control arms....the guy I wad talking bout was my fiances cousin and he used to have a yj back in the day and I told him the Jk is way different than previous models but alright thanks man appreciate it!
