DTC P0344 CAMSHAFT POSITION SENSOR INTERMITTENT problem
Old Nov 6, 2012 | 07:52 AM
public646's Avatar
Default DTC P0344 CAMSHAFT POSITION SENSOR INTERMITTENT problem
I have done dtc check, and I got code P0344 its CAMSHAFT POSITION SENSOR INTERMITTENT problem. I just want to know is that serious problem, do i have to take it to dealer right away? Thanks
Old Dec 21, 2012 | 10:47 AM
RDLNJK's Avatar
Just replace the camshaft sensor. Available aftermarket.
Old Jul 22, 2020 | 02:11 PM
Sinpperx's Avatar
Hello I did swap both sensor just to see if that issue with sensor and came up issue with wiring its self in passanger side always issue becouse of the heats of enginee check engine still come on but no code so far I guess cable need to be replace hope some one can share any aftermarket cable can be found and how much cost
Old Oct 20, 2020 | 02:14 PM
cejeka's Avatar
Found the Cam sensor plug replacement here.... https://www.moparwholesaleparts.com/...way-68148103aa
$40
