Dual Batteries ...
I am thinking about using all that space under the back seats of my Rubicon for a dual battery setup. Once thebattery is out of the engine compartment there will be a nice little nesting spot for the onboard air compressor
Does anyone here have any positive or negative suggestions about doing so?
Your thoughts on the subject?
Burndog
Burndog
Burndog
Burndog
Burndog
Burndog
If yours is a 2 Door, then I don't know.
I gave up giving this advice. Most people don't believe it. Only the most expensive batteries recover the vented gas, and then only 90% of it. The rest goes into the surrounding area.
Burndog
Burndog
Figure out something different and keep them under the hood where they belong. I noticed once I put the Airaid in that the empty space where the OEM airbox was would hold another battery with the use of a custom tray.
Would that still increase your amperage draw vs. a single automotive 12v batt?
Or would the best solution be run an Optima with a higher output alternator?
I am concerned about a power source for the new 9000i winches during extended duty...
Have you decided against installing the batteries inside the passenger compartment? Hope so.
Why would you want to permanently install a second battery? Aren't people doing well with the one original battery? There are lots of winches on the trails out there.
You asked for thoughts on the subject, so here you go:
If I were going to need a second battery for winching, I would consider the following.
Get a battery box designed to hold/carry a sealed car battery.
Install leads on the box with a heavy duty DC receptacle on the end (marine supply catalog).
Permanently install the mating plug on the Jeep with leads to your OEM battery so when the second battery is plugged in, they will be parallel.
Make a way to strap the extra battery to the top of the front bumper. It would be there only when needed. Otherwise, securely strap it in the back when you pack for a wheeling trip.
You would have two batteries for winching, both being charged while the engine is running. But, when not wheeling, you are not dragging around an extra battery. It can remain at home being properly maintained and always ready.
This would be a great way to jump start your vehicle if you find a dead battery some cold winter morning.
The steps above are just a brief outline, but the idea is there. I believe it would be worth the extra effort to not have a permanently installed second battery.
About 6 years ago I moved the battery in my 3000GT to the rear hatch area. I used a battery relocation kit that came with a battery box from summit. I haven't had any problems with the set up. It's nice having all that extra space under the hood.
