Dual battery question.
Old Mar 31, 2010 | 04:21 PM
mikegp's Avatar
Default Dual battery question.
I currently am running a 800CCA battery for my jeep with my warn m8000 hooked up to it. I was thinking of getting one of those dual battery trays and hooking my stock battery back up the way the dealer had it when i bought it, then using the 800CCA battery for my winch. is that a good idea, or do i need two batteries around 800CCA's for this idea?
Old Mar 31, 2010 | 04:44 PM
FlameRed's Avatar
With the Optima's, for example, the specifically say on their website that if you're going to have them wired in parallel with another battery that "it must be similary battery of similar age" (see optima website, FAQs). Otherwise the batteries will have different internal resistances and eletricity will take the path of least resistance and you risk not getting full voltage to one of the batteries.
Also, I don't know that the stock battery fits on one of those tray's with a second battery. It's pretty tight with two optimas, and the stock battery is larger than an optima.
The dual isolator's essentially wire the batteries in parallel when the isolator is closed.
Old Mar 31, 2010 | 06:40 PM
jdcjeep's Avatar
Hey Echo- I'll be doing the same install as you, Benchmark dual battery K.I.S.S. system with Die Hard Platinum Marines after you, so I'd love to know how your install goes once you do it.
Old Apr 1, 2010 | 12:41 PM
mikegp's Avatar
ok, i guess i'll have to see if i can fit two of the new battery in a tray.
thx everyone!
Old Apr 1, 2010 | 04:02 PM
dblhelx's Avatar
Would be an excellent picture/ write-up if any of you guys installing it this weekend feels like taking the time to take pix and document. Great addition to the website!
Old Apr 1, 2010 | 04:26 PM
Brashanic's Avatar
cca's is not what you are looking for to run winch and acc's. Ah's is what you need to look at.
