Dual stabilizer rub. Should it?
This is a pic on my dual stabilizer from Skyjacker. I would have sent a pic to them but their web site does not have any email contact. I will call them tomorrow. But till then, should the front plate be rubbing like this? It did not strike anything while wheeling. It was against the track bar at the time of install. I actually grabbed that little plate then with some channel locks and bent it out slightly. I could simply do it some more but I dunno if it is supposed to ride along the bar like that. It would take many years to wear through anything other than paint so I'm guessing it's okay.
Right off hand I would say no, it should not rub. My RC dual stabilizer setup never rubbed like that when i had the 2.5" lift on the Jeep. It did however get crushed, spindled, folded and mutilated when I installed my larger lift. Apparently it didn't play well with the Clayton 4.5" I know have a single Bilstein and it works great.
Tie rod definitely not bent, the shocks tilt down towards the center mount giving that impression in the pic.
Skyjacker is a local company (Louisiana) for me so I didn't think twice about buying their product. They do alot for their local community (as I'm sure any successful off road company does where they are) and this small issue is just another tweek needed in the list of things modified. Tweeks are often needed in even the best engineered products we get. The missing boots probably rubbed (no pun) me wrong the most.
