Duel Stabalizer
Old Oct 24, 2011 | 02:53 PM
Scootersjk's Avatar
Default Duel Stabalizer
I have a 2010 2dr sport with 3.5 in lift, 2.5 budget boost rough country with track bar relocation and bigger sway bar links front and back. It has Rubicon Springs and Skyjacker Nitro shocks. I am running 33s. My question is??? I am thinking of adding a duel stabelizer. I tow an 1800 pound pop up camper. i am also adding a gobi rack which will have two kayaks on it. Do you think that duel stabelizer would be a benefit, or just upgrade stabelizer shock? Any advise would be excellent........
Old Oct 24, 2011 | 03:28 PM
Ryan0260's Avatar
No benefit a single stabizer is fine. They are more for show
Old Oct 24, 2011 | 03:33 PM
Hook-Em's Avatar
Originally Posted by TheDirtman
Are you going to have them fight?(duel) or are you going to run two of them? (dual)
Just messing with you. One should be fine they really do very little anyway.
Lol - I thought the same thing, just didn't post it.
Old Oct 24, 2011 | 03:47 PM
DONKEY-PUNCH's Avatar
I had the rough country dual set up with their shocks and it felt just the same as stock. A month or so later both shocks blew out. I read on the forum about a dual set up and MOST people will say not to use them and so on. Well... I took my 2010 rubi to King shocks in Garden Grove and they took what Rough Country had and made a cool "looking" product actually "work"! So you can listen to guys who probably never had a dual set up and are just passing along negative comments from guys on the forum who have a title greater then NEWBIE. On the other hand if your rig is not a daily driver, don't waist your money.
Old Oct 24, 2011 | 04:05 PM
Scootersjk's Avatar
Have any of you guys pulled a camper or trailer at your max recomended towing lbs with the stabelizer?
08JKRHD's Avatar
I don't even have a steering stabilizer....
Old Oct 24, 2011 | 04:23 PM
So what valve rate are the kings running? Any picts?
I ran dual bilstiens and didn't notice any difference.
I have no clue brother man. KING did their thing and I paid for them. All they said was their single set up was having issues due to the rigs pulling to the left so they were working on lowering the rating and since I had a dual, he would have both at the highest rating and run a longer, bigger diameter sock and rod. I'm no expert in shocks but that's what was done when I went in for shocks all around. Ill post pics when I get home but I tossed the rough country ones so I can't do a comparison.
Old Oct 24, 2011 | 04:34 PM
Grognard's Avatar
I have a dual stabilizer, and it makes a huge difference if I am driving the river bed at Disney OK. The place is so pitted that you wear yourself out fighting the wheel all day, which is what you do if you have a single.
Also the RC dual stabilzer will relocate it above the tie rod cheaper than a single and relo brackets.
But a single is good other than that. Disney is maybe an hour a way, and so is what my build is geared to. Not trying to talk you into it, but there are places where a dual comes in handy.
Old Oct 24, 2011 | 06:41 PM
Scootersjk's Avatar
Bump............
Old Oct 25, 2011 | 04:06 AM
w squared's Avatar
If you don't have steering or suspension issues, you won't see any benefit from a dual stabilizer. If you do have steering or suspension issues, the dual stabilizer will just mask them for a while. Either way....you're not getting much of a benefit. Whether you're pulling a trailer or not, a steering stabilizer is not a solution to a problem - all it does is smooth out the road feel that you get into your steering wheel.
