Dumb Arb Bumper Install Question....
Old Jun 26, 2009 | 10:51 PM
JEEPJK's Avatar
Default Dumb Arb Bumper Install Question....
I am a newb, be nice to me.......
Alrighty, things are going well....bumper off Jeep, cut those crush cans off, installed the lights and just finished up installing the fog light portion of the install...i think I'm doing good so far. One question - there is no mention of using LOCK WASHERS or LOCK TIGHT in the instructions....the box does contain some Lock Washers and the nuts have a bit of teeth (?) on them to hold. I can see using the Lock Washers when I attach the bumper to the jeep tomorrow, but what about the brackets for the fog lights and the side braces...may not be enough of them.....I am doing the specified tourque settings.......any guidance for this newb.....my kids think the jeep looks cool without the bumper...go figure...
Thanks.
Old Jun 27, 2009 | 04:51 AM
c90dan
Guest
Posts: n/a
I didn't use the lock washers on mine. I checked them a couple weeks after install and none were loose. I'll take luck over skill any day. Here's some info I learned installing mine. Screw the bolts into the bumper before you install it, they have a pretty snug fit and when your putting the bumper on it helps having the threads already "warmed" up . Then, when installing the bumper don't tighten the bolts until you get all of them started. The bumper has pretty tight tolerances for the mounting holes, I found cussing a lot helped get them in position.
Old Jun 27, 2009 | 05:02 AM
bOLsAK=3's Avatar
Yeah, there are a bunch of screws that go undocumented in the instructions. I just didn't use them. I think that they went with the license plate plipper-upper thing.
Old Jun 27, 2009 | 07:48 PM
JEEPJK's Avatar
Thanks gents...it is now on!
Old Jun 27, 2009 | 08:07 PM
RescueGreen#3's Avatar
not until I see pictures it isn't!!!
Old Jun 28, 2009 | 04:55 AM
ScottW's Avatar
Lets see some pics and how much did the bumper weigh? Did your front end squat with it?
Old Jun 28, 2009 | 12:47 PM
JEEPJK's Avatar
Camera battery was about to die....snapped these quick....Next Stop...LOD Rear, then a 3 inch lift.....
I did not notice any squatting in the front end at all.....all my buddies were away and I could'nt wait to throw it on, so I did it all myself....held the bumper up on my own and all....its freakin heavy duty!! If your in Canada...call STAN at www.northridge4x4.ca
Old Jun 28, 2009 | 01:00 PM
bOLsAK=3's Avatar
It looks soooooo purdy
