dumb guy, in search of answers
Yes I knew I had a RC lift....that was my mistake on the typo. Anyway, the private seller I bought it from bought it from another gentleman a couple years ago and the original owner is the one who put the lift on. The story I got was that the original owner had a dealership install the lift. Regardless, I love the Jeep I just wish whoever had put the lift on would have finished the job....more to a lift than some taller springs and big tires.....this is my first lifted vehicle so I’m learning a lot.....and the hard way ha ha!
I disagree. Control arm brackets are a great solution for many people who aren't doing hardcore wheelin'. They are monumentally better than cam bolts and also position the arms at a better angle for pavement purposes than mid/short adjustable arms do. Can't say I've ever seen CA brackets "destroyed". Scraped up over the rocks, sure.
In addition to the raised rear trackbar bracket, with 4" coils be sure to check the brakelines so they don't rip off when the suspension is drooped. Not a bad idea to look into unhooking and/or extension brackets, or even new lines. Bumpstops should be integrated into those shocks, so not a must-have, but not a bad idea to think about adding some. And as part of regular maintenance, be sure to crawl underneath and check that front driveshaft at the tcase. When the joint starts spitting grease, you'll have a little time to decide which way to go with it.
And yeah, for a daily driver, Control Arm brackets will be just fine. At some point in the future if you start spending a bunch of time in the rocks, you can always swap them for a set of arms.
