Dyna bead or not
Old Sep 1, 2013 | 04:09 PM
CPT_D's Avatar
Default Dyna bead or not
Just got my 37x12.50x17 ProComps with Walker Evans and can't decide if I should go Dyna bead or "traditional" balancing. We wheel about twice a month but the rest of the time is spent as a DD. If I do go DB should I just get the normal beads or the "off road & aggressive pour packs" that don't require a filtered valve core but they are pour in only?
Old Sep 1, 2013 | 04:56 PM
snakeyes76's Avatar
I would just balance normally with sticky weights. My experience with dynabeads was not pleasant. If you do go with them, make sure you get the ones that don't require the special valve core.
Old Sep 1, 2013 | 09:23 PM
CPT_D's Avatar
Thanks, I think I'll take at least one wheel and see how it balances, I guess the real benefit of the beads is if you have to pop a ring for some reason there would be no reason to rebalance. I figure if it doesn't take much to balance the first wheel I'll probably stick with the weights...
Old Sep 2, 2013 | 04:57 PM
Marmot mb's Avatar
I love my beads i will never use weights again.
Well worth the $25 per tire.
Old Sep 2, 2013 | 06:31 PM
j3r3myjam3s13's Avatar
Ok what is a dyna bead? Never heard of this before
Old Sep 2, 2013 | 07:03 PM
Doschmafia's Avatar
I agree I have worked with them pain in the rear
Old Sep 2, 2013 | 07:33 PM
ronin2120's Avatar
Vet Army
I used an 8oz bag per tire (35" Nitto trail grapplers on 17" AEV beadlocks) no issues. Almost 30,000 miles without an issue. From my research nittos and toyos seem to balance easier then other tires.
Old Sep 2, 2013 | 07:50 PM
pmraider12's Avatar
Had the beads in my 35s on my cherokee. Never had an issue.tires were kuhmo road venture l71 mt's.loved them.friends had them also never had an issue.
Old Sep 3, 2013 | 01:37 AM
rvator's Avatar
I have run dyna beads for the last 25k. They have worked great.
Old Sep 3, 2013 | 01:49 AM
Jethro0417's Avatar
I like my dynamic beads but you should go with the larger ones that don't use a filtered valve, it makes airing back up more difficult.
