Dynatrac Evo coil 2 door caster question
Old Jan 6, 2017 | 04:40 AM
bl17z90's Avatar
Default Dynatrac Evo coil 2 door caster question
Hey guys, I am putting my new PR44 on my Jeep in the next couple weeks and I always hear people say that the Unlimited model is built with extra caster for lifted vehicles. Does anyone know the exact specs for this?
I currently have Evo 3 inch coils on my 2 door and Rock Krawler lower adjustable arms. Anyone know what length they need to be for everything to be in spec and if I will NEED upper adjustables?
Old Jan 6, 2017 | 06:01 AM
kjeeper10's Avatar
Vet Army
10° i believe
I would shoot for 5/5 split
Remove lowers, place jack under pinion. Use a angle on the pinion output (+5°)
Take one RK arm, bolt up frame end and spin the axle side joint so the bolt slides in.
Snug down jam nut. Remove arm, pair together and slide to bolts through to match the lengths.
Tighten jam nuts (275-325), install and bolt torque (125), done.
Old Jan 6, 2017 | 06:10 AM
jedg's Avatar
Vet Army
Yup... 10 degrees of separation.
https://www.dynatrac.com/downloads/P...20FAQ_revK.pdf
Old Jan 6, 2017 | 06:16 AM
bl17z90's Avatar
Thanks guys.
Old Jan 6, 2017 | 07:02 AM
TheDirtman's Avatar
If it is caster corrected and you are running close to what size lift it is caster corrected for then you should be same length as factory arms.
Old Jan 6, 2017 | 07:36 AM
Dynatrac's Avatar
Sponsoring Manufacturer
The caster that is built into the ProRock 44 unlimited housings is 10 degrees of separation between the pinion and caster axis. The axle can be adjusted using the control arms between 6-8 degrees caster and 2-4 degrees at the pinion. Adjustable upper control arms will help with aligning the axle, but consult with the shop that is performing the install to see what they recommend for your exact set up. Visit www.dynatrac.com and review the FAQ document on the website under the ProRock 44 section. This will help you with the technical questions that you have regarding your ProRock 44. You can also give us a call at (714) 596-4461 and we can help you with any additional questions.
