Dynatrac question
Old Mar 25, 2013 | 06:25 PM
arb123's Avatar
Default Dynatrac question
I just installed a set of 40x13.50 good year tires and I am rubbing big time on the frame and my swaybar. I have dynatrac 60 axles and was told that i need to adjust my steering stops. I am not exactly sure how to adjust the steering stops on the dynatrac axles?
Any input would be greatly appreciated!
Old Mar 25, 2013 | 06:39 PM
ghostjk's Avatar
Unless I'm confuse I think you are talking about the steering stops located on the knuckles. It's a small bolt that sticks out of the knuckle on the inside back side. You take that blot out and add a washer which shortens your turning radius and stops the rubbing.
Anyone please correct me if this is incorrect. I have the prorock 44 and reused my factory knuckles.
Old Mar 25, 2013 | 06:42 PM
dahreno's Avatar
It's a real bummer that with a set of axles like that , you have to limit your turning radius . Maybe consider a set of wheel spacers .
Old Mar 25, 2013 | 08:12 PM
ghostjk's Avatar
Wheel spacers would help. If your back spacing is greater then 3.5 inches. 40's are huge. I really don't think there is any way you couldn't cut down on your turning radius with that big of a tire. It has nothing to do with the axles. Unless u were running the wider D60's which would help bc it would push the wheels out further
