Dynomax exhaust
Old Jun 7, 2011 | 03:47 AM
rws's Avatar
rws
Default Dynomax exhaust
Anybody have these in stock? I need a new exhaust immediately as mine got crushed by my rear trac bar. Seems that nobody has this system and the company is out of stock as well.. I don't even need the cat back system, I can make due with just the muffler.. Any other systems I can get ASAP that is similar with a mellow sound, no drone, and out of the way of the rear trac bar??
Old Jun 7, 2011 | 05:40 AM
Merlin4979's Avatar
Have you tried Summit Racing?
Old Jun 7, 2011 | 06:07 AM
Imposter_LRF's Avatar
Stock track bar location? If so...the 39459 part number is What you want. In stock at summit racing.
I hate drone too. There is none at 55 and only a hint at 70.
If you are doing just a muffler, go with one of our VT Series. Made to be drone free, however there is no bolt on cat back from dynomax yet...
Old Jun 7, 2011 | 06:52 AM
rws's Avatar
rws
In stock!! Thank you..
Not stock, rear trac bar from a RK X-Factor LA.. I wasn't aware the VT systems were available yet.. How does the VT compare with the Ultra Flow SS? Same sound only quieter? Can it be mounted under the driver's seat?
Old Jun 7, 2011 | 07:17 AM
They aren't for a bolt on jk application. However you said just doing the muffler...so its just a thought if you wanna do custom.
Its tuned to be be aggressive on the wide open throttle... but very mellow at cruise and drone free
I will post a pic of my rear track bar with the high clearance exhaust and you can see if it will work for you because I am not familiar with that track bar setup.
Old Jun 7, 2011 | 07:27 AM
rws's Avatar
rws
Ultimately, I'd like the exhaust to dump right before the rear axle. Will this muffler work with that type of application?
Old Jun 7, 2011 | 08:26 AM
Here is Eddie's JK dumped before the rear axle. While his Dynomax muffler is round, it would be similar for the oval VT series mufflers.
Old Jun 7, 2011 | 09:32 AM
rws's Avatar
rws
Cool.. PM sent
Old Jun 7, 2011 | 01:17 PM
Jeepnut67's Avatar
Smile Ordered mine!
Got mine coming from Summit! Should be here thursday. Can't wait to see what it sounds like with the Airaid CAI
Old Jun 7, 2011 | 01:29 PM
Mine sounds amazing with the banks cai
