E-DIsco removal question
Just a quick question for all those who have removed there electronic sway bar for a replacement such as teraflex or currie setup.
What did you do with you wires after you cut the harness off?
I haven't done it, but if I did, I'd just cap them with a crimp-on, and tuck them away.
Was it required to cut the wires for some reason?
Do you have a tuner that will allow you to disable the sway bay malfunction light?
What are your plans for the old sway bar?
old swaybar is sold so I cut the wiring harness to send with the bar for another member to install.
I was wondering if there was a setting for that on the superchips flashpack... anyone know??
or I was going to see it the dealership could cancell it out
Right now I just put a beag of silicon on each wire end then when that dried I siliconed the whole group of wires together then wrapped them in tape...
