Eagle Alloy Wheels
Old Mar 18, 2008 | 09:45 AM
sjbissett's Avatar
Default Eagle Alloy Wheels
Anyone running the Series 187 16x8 with 4" of backspacing. Are there any issues running with 4" of backspacing or anything special that needs to be done to run these on a 4D Sahara. I am looking at 305/70r-16 tires to go with them.
thanks
Old Mar 18, 2008 | 09:50 AM
kylepatrick's Avatar
thanks
I'm running the 17" AE's with no problems whatsoever, I wouldn't thnk there would be an issue.
Kyle
Terraflex 2.5 BB w/shocks
17x8 American Eagle 114 Chrome
305x65x17" BFG AT/KO
Old Mar 18, 2008 | 11:19 AM
sjbissett's Avatar
I will have a 2.5" lift. What is the difference between offset and backspacing? What types of rubbing issues might I have?
Originally Posted by jkdrone
Well, they have 4" of BS, which is good - I don't know about that -11 offset though. Probably won't be a big deal. (Might have rub @ full-lock w/o much lift and wider tires.) I have the Series 140 17x8 in +2 offset 4.5 BS w/ 2.5" lift and 35's. It rubbed on the air dam until I took it off.
!c
Old Mar 18, 2008 | 11:41 AM
jeepguru's Avatar
I'm running that exact size in the 186 series and they fit fine. I have 315/75/16 w/ a Tera BB 2.5" and the only place the tires rub is on the stock front bumper at full compression w/ swaybar disconnected.
BTW I'm selling mine if your interested, I want to go to 17s to run 37" tires.
Old Mar 18, 2008 | 11:45 AM
sjbissett's Avatar
That article helps me understand it alot better. Thank you...
The reason I posed the original question is because some people have noted issues with the Cragar soft 8's 15x8. The offset and backspacing is close to the rims I am looking at and I'm not sure if the issues reported with the cragars are due to the rim size, backspacing or offset. Anyone have any thoughts on that?
Well, I had it a little backwards (easy to do w/ -/+ values =) the negative offset should help to fit them. Here's a decent article on the subject:
fourwheeler.com/techarticles/wheels/129_0602_wheel_backspacing_etiquette/
!c
Old Mar 18, 2008 | 06:35 PM
Mountjk's Avatar
I have that exact wheel and have no problems running 35inch tires other than having to trim the plastic crap under the front bumper.
Old Apr 5, 2008 | 06:17 PM
sjbissett's Avatar
You still selling these? PM if so
!c
Old Apr 5, 2008 | 06:22 PM
Rubicon Rando's Avatar
i am running AE 185's 15x10 -45mm offset and no issues, no rubbing lock to lock
i drove my heep maybe 10 times this winter and the rims are rusting already... i have had them for maybe 2 months
Old Apr 5, 2008 | 06:55 PM
08SaharaM6's Avatar
I have 16x8's with a 4" BS and 12.5 tire with no problems.
Old Apr 5, 2008 | 06:59 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
i will be running these as soon as i get my shocks for my FT 3" ultimate klit.
