Eaton E locker help
Old Apr 24, 2014 | 08:43 PM
genesis121's Avatar
Default Eaton E locker help
I installed a Eaton E locker on my Dana 30 awhile ago and I can't seem to get it to work. Anybody have any trouble shooting ideas? So far I have checked and am getting current to the switch and the unit. Maybe I am not getting enough current to activate the solenoid?
Here is a video I shot to see if it was engaging or not and I am pretty sure it is not
http://youtu.be/rf4uVEDs9oo
Old Apr 30, 2014 | 09:54 AM
genesis121's Avatar
anybody have any advice about this?
Old Apr 30, 2014 | 10:12 AM
Mark Doiron's Avatar
It did not appear locked in the video. Here is what i would do:
Jack up axle, lock, spin tire by hand. Check both tires spin together the same direction. You suspect current too low: Run heavier gauge wire direct from battery to locker wires out of diff and repeat locker test. No joy? Open up diff and play with locker; see if you can unjam something. Still no good? Contact Eaton. You have a warranty, right?
Old Apr 30, 2014 | 10:18 AM
genesis121's Avatar
Good idea, I will try and use a heavier gauge wire directly from the battery. My 12 month warranty expires in June.
