ebs esp lights on and the stering wheels no longer in the middle
Old Jun 10, 2011 | 02:38 PM
HV's Avatar
HV
Default ebs esp lights on and the stering wheels no longer in the middle
ok all mighty JK forum members this is my issue see if any one can help out with me with it my esp ebs light came on last week and now the stering wheel is no longer in the middle . any thoughts thanks
Old Jun 10, 2011 | 02:45 PM
Mark Doiron's Avatar
Check that your draglink is properly adjusted and the turnbuckle bolts are tight.
JEP THNG's Avatar
did you recently wheel it or did you put a lift on? that is what it sounds like to me. go to the write up section and you will find a write up on " do it yourself front end alignment". Steering wheel is an easy fix that only takes about 15 min. to get it right. this should solve the problem.
Old Jun 10, 2011 | 04:59 PM
JKcondrey's Avatar
yeah, if you installed a lift, adjust the draglink for sure. If you just went wheeling and its like that now, you bent something. Check the entire suspension. After centering the wheel, your light should go off.
