ECTED lockers?
The quote from the Aussie site simply says that they don't recommend putting "a locker" in the front when driven on icy conditions. They're just referring to their auto locker. A selectable locker that's not locked would simply be an open diff (or an LSD in the case of the ECTED) which would be inline with their recommendation of "no locker". If that makes sense...
As far as the ECTED, I've read that the "locked" setting is really just a REALLY strong LSD and that it's not TRULY locked as it would be with an ARB, OX, Aussie, Detroit, etc. Also, have read that the ECTED will not withstand the abuse of tires larger than 35". Anyone have experience with the ECTED above 35"?
If you are going to re-gear you should do both at the same time then because if you are paying to have them installed you get them installed for free because they are allready taking the diff apart and it is less work for them to re-gear cause they don't have to take the ring gear off the carrier and put the new one on. Front and rear gears and ected lockers about $3300 installed. Thats what I paid.
Only needs to be selectable if you drive on ice/snow alot. Otherwise you can go with an auto locker.
Sounds lile an Aussie front won't work for me b\c I drive through a fair amount of ice and snow during the winter. Right now I have "standard" differentials front and rear
Does it make sense then to put an Aussie in the rear and a selectable locker up front?
I don't think you want an auto locker in the rear when driving on snow/ice either, but I'm not 100% sure. I doubt it'd be as important as the front, but still think it's unadvisable.
It increased my turning radius a bit, but not enough to make me wish it were selectable.
