Electric Sway Bar Disconnect
Old Jun 6, 2011 | 07:15 AM
JAFHR's Avatar
I was just using my 09 Rubi the other weekend for the first time off road. I read the manual (oh after I went) but found out that it works in both 4H&L. You put it into 4wd then select the sway bar disconnect. It will flash at you until it disconnects. The requirement is for uneven road that would cause the disconnect. The light will go steady when it's disconnected. You also feel (especially in real rutty areas) that the front end is real loose and floating. If you go 19 mph or higher the sway bar will reconnect on it's own, and the light will flash continuously. This is due to safety reasons according to Jeep.
Old Jun 6, 2011 | 10:16 AM
Al-Raisi's Avatar
I've tried that exactly many times in the past but it just didn't disconnect even (on the level place like tarmac)
but first thing i'll try tomorrow is what Biginboca suggested
Thanx Dear
Old Jun 6, 2011 | 10:17 AM
Al-Raisi's Avatar
Originally Posted by ronjenx
It disconnects in 4hi, too.
Go here to see how it works, and why you may need to move to get it to disconnect/re-connect:
https://www.jk-forum.com/forums/show...rtbar%29-Study.
Thank you very much..Now I understand how the system operates
Old Jun 9, 2011 | 11:20 AM
Al-Raisi's Avatar
Originally Posted by Biginboca
If I recall correctly it only disconnect in 4low also. So you need to put your transfer case into 4low, push the disconnect button, and then drive a bit on level ground before it will disengage. The light will flash a bit at first but after driving maybe 10 feet the light should stay on indicating it has disconnected.
Thank you very much for you advice...what ever you have suggested worked perfectly .Both disconnecting or connecting required the car to be driven for few feet and sometimes turning the wheels left and right.
I would like to thank everyone for the suggestions which made me more knowledgable .
