Electric sway-bar discounect?
Originally Posted by Radioman
I'm somewhat confused, my Rubi sway bar disconnect works in both 4H and 4L. It will attempt to reconnect at speeds above 18 mph. OP says his will work only in 4L...
I doubt the programmers will override this since above 18mph disconnected could be dangerous.
Originally Posted by JamesWyatt
They do disconnect in 4H, they probably haven't tried it.
Maybe on a Canadian JK, but not on a U.S. JK. The dealer "can't do it", either.
For those who may get the feature confused with other owner programmable features...
What I an referring to is, I would like to prevent the headlights from turning on when I unlock the doors with the remote.
So far, I have not seen a successful way for me or the dealer to accomplish this on a U.S. JK.
Lockers are 4-Lo only. Sway-Bar disconnects in 4-Lo or 4-Hi from the factory.
FYI .. one of the bolts fell out of my sway links while wheeling last weekend. I ran disconnected for several days including driving home from North GA mountains until a got another bolt. I really didn't feel that much difference running disconnected vs. connected. I had no problem running highway speeds and cornering.
I believe your wrong. I own the traildash, the option to disconnect the sway bar is on the same screen layout as the diff lockers. ( The screen with both axles on it ). I supposedly did disconnect the swaybar from the traildash, the trail dash lit up and indicated it was. Now I never did go offroad, flex and confirm it was disconnected. All I had to go on was the traildash telling me it was disconnected. I only got it a month ago, never had a chance to get on the trails yet, and its the dead of winter.
All other JKs must visit the dealer to get the headlights reprogrammed to stay off when unlocking.
Without EVIC there is a dance that will let you program what the lights do when you lock the Jeep, but not when you unlock it, unfortunately.
