Electrical Help Please
Old Nov 4, 2013 | 06:35 AM
AF_Jeeper's Avatar
Default Electrical Help Please
Morning guys, I'm in need of a little help with the electrical layout in my 09 Rubicon.
I'm trying to plug into my data link connector underneath the steering wheel but it's not supplying power. I've checked all the fuses under the hood and they are all good. Do I possibly have a bad relay or what? If so, anyone know which one?
Thanks for your help,
Shaun
Old Nov 4, 2013 | 03:33 PM
AF_Jeeper's Avatar
Default Anybody?
I checked the pins for kinks and did not see any. I checked the pins, the grounds (#4, #5) both work when tested. The I checked pin #16 for power and got nothing. Thoughts???
Old Nov 4, 2013 | 04:56 PM
karls's Avatar
Mine was a fuse under the hood, but I trust you've checked all of your fuses. Check the wire on the backside of the connector and see if you've got power there.
Sent from my GT-P5113 using Tapatalk 4
Old Nov 5, 2013 | 05:42 PM
AF_Jeeper's Avatar
Yes, I've checked all the fuses and they were all good. I will check the back of the plug.
