Elementary lift questions
Old Mar 24, 2011 | 09:03 AM
Abbotsford50's Avatar
Default Leveling kit question
Teraflex Leveling kit
I am certain I've read some posts which say I need to add to my bump stops, and/or use extensions for the shocks, and possibly adjusting the front brake line... yet other posts have said nothing more is needed other than just putting in the spacers.
Old Mar 24, 2011 | 10:59 AM
zippyd8's Avatar
These things may be needed depending on how much lift the leveling kit gives...
For example, If it is a small lift (1" or so), you don't need anything. If it is a larger lift (3" or so), you will need this stuff.
Old Mar 24, 2011 | 11:03 AM
Fenrir's Avatar
I just received my TF leveling kit (2" front, 1" rear) and the only thing I bought with it were the JKS sway bar disconnects for 0" to 2" lift. I'm good to go!
Old Mar 24, 2011 | 11:07 AM
GreenJK07's Avatar
You don't need anything more with that lift. Most people who are using shock extensions and brake line brackets have lifts already installed and they are using coil spacers to get more lift. With your kit, it will have everything you need. I wouldn't change bump stops unless you go over 3" in lift. I'm running 2 1/2 rubicon express lift and have stock bump stops and no extended brake lines. Even at full articulation the lines are fine. Hope this helps.
Old Mar 24, 2011 | 11:45 AM
Thanks for the help
Old Mar 24, 2011 | 01:43 PM
Hifirush's Avatar
Hey Green, since you don't use bump extensions, do you ever rub with your tires? I figured they come with the kit, we needed them.
