Engine compartment extra hot??
Old Sep 13, 2011 | 06:43 PM
NeverStock's Avatar
Default Engine compartment extra hot??
Stopped to fill up on has tonight and decided to check the oil. Oil was fine but when I lifted the hood it was extremely hot under there. Granted it was 102 here today in Dallas...is this normal... ???Is that the reason the heat reduction hood is so popular?
Any other way to help reduce the temp under there?
Old Sep 13, 2011 | 06:46 PM
Ryan0260's Avatar
Yea jeep engines run real hot in general. I think some tuners allow you to kick the fan on at lower temps which might help some
Old Sep 13, 2011 | 06:47 PM
ronjenx's Avatar
If your engine temp gauge was straight up, and you were not getting the transmission HOT OIL warning, the heat you felt under the hood is normal.
You may want to think about an auxiliary transmission cooler, though.
Old Sep 13, 2011 | 07:15 PM
jeeeep's Avatar
I'm here with you - I hate opening the hood in this Texas heat, like opening the gates of hell.
I do a lot of driving in town and freeway everyday and haven't had a problem, when I get home sometimes I'll open the hood and let cool.
Old Sep 13, 2011 | 08:25 PM
NeverStock's Avatar
I have the B&M tranny cooler...temp gauge was normal...and no hot oil message... Have not had that since installing the tranny cooler....
Sounds like it is normal... Might try to lower the fan setting though using my superchips...
Thanks for all the replies!!!
Old Sep 13, 2011 | 09:09 PM
wtrskier30's Avatar
I was thinking of trimming my inner fenders to let some more "cool" air flow through...would really like to find a mesh style inner fender cover...if anyone knows of such a thing, let me know....
Old Sep 13, 2011 | 09:24 PM
Red Dog's Avatar
Are you saying you got the hot oil warning driving on the street?
The heat you feel opening your hood after you stop is normal. When you stop the air around the engine is not moving anymore and heats up. The temperature outside has little to do with the temperature of the internal engine it is made to cool the engine at temperatures that make humans uncomfortable. The main thing is air flow thru the radiator.
