Engine Intergrity and Supercharging
Old Nov 25, 2010 | 05:22 AM
1230frstap's Avatar
Former Member
Default Engine Intergrity and Supercharging
Hi All-
I am no expert, by any means, but isn't it true that the internal components of "stock" engines should be fortified when adding things like a supercharger? If this does not happen, isn't the life of the engine going to be drastically shortened?
Just curious...
Old Nov 25, 2010 | 05:27 AM
mdmmd's Avatar
Talk to Ross at Ripp Mods. He's taken the 3.8 block apart and found that it is actually built extremely well with many of the features you would expect to find in a SC ready engine.
Old Nov 25, 2010 | 05:32 AM
1230frstap's Avatar
Former Member
That's certainly an option, but I was just hoping for some feedback from the forum, as it is stacked with insanely knowledgeable Jeepers
Old Nov 25, 2010 | 06:49 AM
RIPPMODS's Avatar
Sponsoring Manufacturer
Originally Posted by jehnmg
Hi All-
Just curious...
We appreciate your perspective and we hope you find your answers through this knowledgeable community. Our client will certify that we have always shared ethical and factual information with all JK web based communities, for that reason we will take a stab and answering your question.
This engine seems to have gone through the paces at Chrysler, we suspect and its our position that the manufacturer knew that these rigs would be modified with forced induction. When we went through our test paces we purchased an 05 caravan 3.8l V6 with the intention of learning the engines weakness's. After we complete 30k miles of supercharged testing we took the engine out of our 07 to see what suffered. What we found was the 07 JK engine was completely different inside and many of the question we would have, were already addressed... such as piston design and coating, stronger rods, metal head gaskets and additional oiling.
Additionally with the nearly 500 kits we have on the road - short of 2 reported head gaskets there has been zero engine failure from the rotating assembly.
Lastly RIPP isn't looking to break your Jeep; we set this kit up to deliver boost more like a low pressure turbo than a "blower". The term Blower, refers to roots type superchargers which deliver boost much more aggressively as opposed to the predictable boost scale of a centrifugal (enter the arguments).
Question welcome
RIPPTECH
Old Nov 25, 2010 | 06:53 AM
mkjeep's Avatar
While your on here RIPP, what are your feelings on installing a SC on an engine with 65-70,000m ? Or in other words, do you have many peeps that have installed one on a higher mileage jk?
Old Nov 25, 2010 | 07:44 AM
RIPPMODS's Avatar
Yea - enough guys have to be sure in saying yes - best thing to do is do a compression test to make sure the cylinders balance is the same across the board. Call the shop speak with the techs they have a lot of info on the engine...
RIPPTECH
