Engine wont shut off?????
Old Oct 13, 2015 | 11:19 AM
Sublime's Avatar
Default Engine wont shut off?????
2010 Jk manual transmission, got home turned the key to off and engine keeps on running without key????? Had to stall it out just to shut it off???? Any help please ???
Old Oct 13, 2015 | 11:33 AM
Sublime's Avatar
Anyone??
Old Oct 13, 2015 | 11:41 AM
Invest2m4's Avatar
Sounds like you fixed it. Let us know if it happens again.
I'm not an expert on the ignition, but sounds like maybe a relay stuck open or a loose wire.
Old Oct 13, 2015 | 11:49 AM
Sublime's Avatar
The same think happens as soon as I start it back up
Old Oct 13, 2015 | 12:18 PM
Sublime's Avatar
It seems to shut off on its own after about a minute . (same as headlight delay) ??
Old Oct 13, 2015 | 12:44 PM
jedg's Avatar
Vet Army
I've heard of this before. At first, they thought it was the TIPM but replacement of the K10 relay seemed to fix it.
Old Oct 13, 2015 | 01:20 PM
Alp1n3's Avatar
Have the TSB checked at the dealer and you might need a new ignition switch
Old Oct 13, 2015 | 03:32 PM
brankz's Avatar
Maybe the ignition cylinder 😕
Old Oct 14, 2015 | 08:11 AM
Sublime's Avatar
Left the battery unplugged all night and I drove it to work and no issues, I thought maybe the relay was fried because when I turned the key off, all the accessories shut off but the engine continued to run? Hopefully an isolated incident ??!!??
Old Oct 14, 2015 | 10:10 AM
Yankee's Avatar
It could be. My 2007 has done a few weird things over the years. I have caught the flicker of one of the warning lights while on cruise control that will kick the tranny out of OD for a moment. Does not shut off the cruise and no codes ever and has done it once or twice a year since 07. Three times over 8 years my power windows stopped working, until I restarted the vehicle.
If it does not reoccur then all you can do is shrug.
