Engine wont shut off?????
Old Oct 23, 2015 | 02:54 AM
  #21
Sublime's Avatar
Well.... She's at the dealership ;(
Old Oct 23, 2015 | 03:21 AM
  #22
Rednroll's Avatar
Hopefully, it's something that won't cost you an arm and a leg. You've covered everything that I could speculate already. The only other thing I would guess is that it may be ECM or potentially clutch related since you own a manual.
Old Oct 23, 2015 | 05:08 AM
  #23
Sublime's Avatar
I could definitely see this being computer related, but not too sure about being clutch related, How would the clutch keep the engine and all the electronics running?
Old Oct 23, 2015 | 05:22 AM
  #24
Rednroll's Avatar
I'm really just taking shots in the dark in regards to the clutch and since I've never heard of anyone with an auto describe this problem and because there's a lot more auto-trans JKs than manuals, it just leads to further speculation in that direction. However, my thinking is that typically when you push in the clutch pedal there are switches that get activated/de-activated and from doing a brake kit install, I know the clutch is connected and wired with the brake Master Cylinder. So it wouldn't surprise me if the clutch is tied in with the ignition system in some manner. Is it possible to crank the JK to start it, without pushing in the clutch pedal when you have it in gear?
Others have wired "Kill switches" in their JK and those connectors where they typically tie the kill switches into is located in the same vicinity nearby the MC under the hood as well.
Old Oct 23, 2015 | 07:42 AM
  #25
Sublime's Avatar
It's funny that you mentioned the clutch because last week when I called about recalls they said my clutch interlock switch was on recall but when I got to the dealership they had no recalls on file for my vehicle so I just called jeep back and know they have no records either? Lost?
Old Oct 24, 2015 | 02:08 AM
  #26
Rednroll's Avatar
Hopefully things work out for you and they find the clutch interlock switch is the problem and then something pops up in their system that there was a recall and everything falls into place and it doesn't cost you anything to get it fixed.
Old Oct 24, 2015 | 02:53 AM
  #27
Sublime's Avatar
Bad TIPM. Still can't figure out how jeep can recall the same computer from hundreds of vehicles, but will not acknowledge others simply because there has not been enough complaints yet, obviously there is an issue with computers they are using.
Old Oct 24, 2015 | 09:14 AM
  #28
Rednroll's Avatar
It sounds like there is class action lawsuit in the works.
Judge Says Chrysler TIPM Class-Action Lawsuit Can Move Forward | CarComplaints.com
The funny thing is that it lists 2010-2014 Wranglers as being in the affected vehicle lists, but states this as well.
The lawsuit alleges Chrysler owners started complaining in 2008 and by the end of 2011, the National Highway Traffic Safety Administration had received over 100 complaints about the TIPMs.
Also it looks like Ronjenx may be our forum expert on the TIPM.
http://www.jeepforum.com/forum/f96/o...study-1200238/
Old Oct 24, 2015 | 12:58 PM
  #29
Sublime's Avatar
I've been in contact with jeep for the last couple days, they said they might be able to give me a partial refund but would get back to me on Monday regarding the final outcome
Old Oct 24, 2015 | 12:59 PM
  #30
Sublime's Avatar
So I just picked up my girl at the dealership
