entire JK vibrations
Disconnect your front driveline from your front axle and use a wire hanger to pull up and out of the way. Keep your jeep in 2WD and take it for a drive. Your front driveshaft will not spin as long as you are in 2WD.
If this takes the vibration away then you have found your issue. If not then reconnect your front driveline and then COMPLETLEY remove your rear driveline. Put your Jeep in 4WD high and go for a drive. If the vibration goes away then it is your rear driveline.
Hope this helps
Hope this helps
If your U-joint is toast already, IMO you have something going on. Did they check your pinion angle?
long ago a friend and myself were involved in a joke that included taping a roll of pennies to a drive shaft. wobble wobble wobble blang! ting! bing! bong!
It sounded like the rear end blow up
. It only took a couple of beatings to make it funny
Top of the list is the pinion angle when I go in .. thats been bugging me since I last really drove it anywhere, except arrands well went offroad.
SOOOOO ... that being said, I am going to have the dealership look everything over twice ... just to make sure. It won't be driving for a while ... least to say I am not going to JK Fest!
