EPi 9.0 Help
Old May 14, 2008 | 09:53 AM
eDiveBuddy's Avatar
Default EPi 9.0 Help
Well, I was trying to mount my EPi 9.0 this morning. But I can't seem to get the supplied bolts into the base of the winch. Is there something I'm not understanding? Should I try reaming the paint out from the base? Any help would be appreciated.
Old May 14, 2008 | 09:56 AM
SoCalChuckster's Avatar
On mine i placed the nuts into the holes in the bottom of the winch. I placed the winch in my bumper and then installed the bolts from below.
Hope that helps
Chuck
Old May 14, 2008 | 11:30 AM
SteelMastiff's Avatar
Hope that helps
Chuck
This is the correct way to install; please don't start cutting on your winch!
Old May 14, 2008 | 12:55 PM
eDiveBuddy's Avatar
Chuck
That is the way I'm trying to install. But there seems to be too much paint on the winch. I can not get the bolts or the nuts in the holes. I tried a mallet with the nuts, but that did not work.
Thanks.
Old May 14, 2008 | 01:22 PM
GadgetFreek's Avatar
I had one nut that I could not install in the winch. Finally had to take a hammer and a punch to get it to line up. Two were really loose and had a hard time keeping them put. One was just snug and the other would not go.....who knows. I did open up the hole on the winch a little to line up with the nut.
Old May 14, 2008 | 01:24 PM
It sounds like you might have a problem then; mine went right in, just needed to have the nut turned the proper way! It wasn't very tight at all...
Old May 14, 2008 | 10:43 PM
eDiveBuddy's Avatar
Got home and figured it out. I had use one of the smaller ones on the fairleads. All is good now thanks!
Old May 14, 2008 | 11:49 PM
Rubimon's Avatar
Did you not get the practice winch install kit with yours?
Just kidding!
Old May 15, 2008 | 04:03 AM
Not to laugh at ones expense; but that right there is funny, I don't care who you are!!!
Old May 15, 2008 | 05:51 AM
dyolfknip's Avatar
LOL...in the box came a white peice of paper with the instructions....take your beer of of it before reading
FYI, THat is the same thing I would have done man....
