esp on 2" lift
Not sure if this is the place to ask this question,but here it is. I recently installed a 2" FULL TRACTION SPACER LIFT ON MY 08 UNLIMITED. I took it for a spin and my esp kept coming on at very slight turns. My steering wheel was a quarter turn but going straight. I got my front end realigned and the esp came on once. Is there something else I need to do since the install.
Hey,
Yea happens usually on a gradual turn, esp comes on and tries to break for you. There is a fairly lengthy thread here somewhere on the subject. Some say a flash to the computer will help, some say their esp cable is rubbing etc. Ive only had it looked at by 1 dealer and they told me "Tough shit you lifted it, here is an instruction sheet how to disable the ESP" ... so yea I can disable it but its not a perm. solution.
lookup the 'basic do-it-urself jeep jk wrangler front end alignment' on project-jk.com... most say that works
Sounds like you need to recenter your steering wheel. It's pretty simple to do and only takes a 15mm socket or wrench.
https://www.jk-forum.com/forums/show...90&postcount=7
At least the problem was solvable.
