Esp aaaaaaahhhhhhhh!!!!!
Hey Jeepers, had a 3" tf lift and 35's put on... the steering is centered... the tires are at 30psi.... And now the ESP is going bonkers around every corner which is driving me nuts... So being the good JK Forum reader that I am, I tried the ESP full off trick which consists of the 4H, the various wheel turning and 7 second holding of the ESP button and no luck what so ever. I can get the chime after the first 1/2 turn, but nothing after that and Im getting tired of fearing every turn. PLEASE HELP!!!!
A) Is the jeep still suppsed to be doing the ESP thing if the wheel is centered and the tires are the right pressure???
B) What the hell am I doing wrong with the ESP permanent disable code???
THanks -T
THanks -T
I had the same problem...
Long story short, something was left un-tightened when one of the shop guys was messing with my Jeep and though it seemed my steering was centered, it wasn't.
My ESP went berserk- but eventually became disabled so I let it go (sick of dealing with the morons at the dealership)
Anyway, a about a month or so later, I met up with Wayoflife (Eddie) on a run- I asked him to take a peek and he fixed it within minutes. (He's the man)
...For the life of me, I can't remember what was left loose- It was the steering box doohicky thinga majig.
Eddie- where are you when I need you?
THanks -T
THanks -T
THanks -T
THanks -T
I'm having the same problem with my 2 door. We just installed a 3" Full traction lift and Pro Comp Xterrain 33 x 13.50 x 18. I took it for a quick spin around the block and the ESP was trippin' out. I adjusted the steering and haven't taken it out for a test drive yet (it was getting late). Hopefully, the ESP will behave better this morning.
THanks -T
THanks -T
It is funny how the computer plays such a big part in this. Even once I had the geometry issues worked out I had one place that would always cause my esp to kickin if I was in 4th but was fine in 3rd even at the same speed. Now it doesn't kickin anymore there, go figure
Good luck I think everyone has covered the reasons and typical solutions.
To answer Wayalife's question, its a 4 door actually, it's just a really picky 4 door for some reason. And you're right about the teraflex being a tall 3" lift, never had to jump into a jeep before.
As for a more positive caster im honestly completely in the dark as to what this is or how to make one more positive. Is this magical doo hickey shamma lamma ding dong majig that DizzyLiz was talking about, or is that just what you look at to tell if it's a boy jeep? ::kidding:: Do I go to the dealership for a new caster or is it a simple adjustment issue?? And thanks again for all the input everyone! -T
