esp bas light keeps coming on
Old Jan 18, 2011 | 01:34 PM
07wrangleruwharee's Avatar
Default esp bas light keeps coming on
i have an 07 wrangler with a 3.5 inch lift and 35s. the other day i was driving down the interstate and my jeep beeped and the traction control light, the esp and bas came on. i went off in about 30 miles and stayed off for a few days. when i drove yesterday on the interstate again it came back on and went back off again in about 30 miles. anybody have this happen to them and what i should do, i really dont want to take it to the jeep dealer because its not under warranty and i just replaced the tranny, i cant afford another costly repair.
Old Jan 18, 2011 | 01:37 PM
JayhawkJeep's Avatar
Veteran: Navy
Most likely all you need done is an alignment. WOL has a good do it yourself otherwise it costs between 70-130 depending if they have to set your castor.
Old Jan 18, 2011 | 01:41 PM
Pluke the 2's Avatar
chances are it might just be your draglink
Old Jan 18, 2011 | 01:43 PM
wayoflife's Avatar
JK-Forum Founder
have you checked to make sure that your steering wheel is completely centered? a steering wheel that is off is the number one reason for esp to go off as your computer will think you are in a slide.
Old Jan 18, 2011 | 01:44 PM
ARinmyJK's Avatar
If the alignment doesn't fix the next easiest thing to check is see if the brake switch is broken.
Old Jan 18, 2011 | 06:29 PM
Northern Wrangler's Avatar
I have no proof to support this and have no idea why it would have any affect on the esp/bas light but have you been driving in snow? My esp/bas lights came on and stayed one once last winter after driving in about 6 inches of snow for a about 20 Km then went off after I stopped, shut off the engine then drove a few hundred feet.
Just the other day I drove about 5 km in about a foot of snow and the lights came on. I got to where I was going, shut off the engine went inside, came out and the lights went out after I drove a few km.
Now I immediately went and signed into the forum to check this out. I read a post from 2007 where someone said to start the engine, turn the wheel all the way to the left, then to the right and then drive it til the lights went out. I did this and the light went out but whether this actually helped or not I have no idea.
Like I said, I have no idea if deep snow caused my lights to come on or why they went out. Just info to chew on.
Old Jan 18, 2011 | 08:17 PM
i did drive in snow and i thought that was the reason but after 3 days in no snow it came back on
Old Jan 18, 2011 | 08:47 PM
George Diaz's Avatar
Default esp bas lights
Have them check the clock spring in the steering col. Mine was replaced and that took care of the problem.
