ESP BAS warning
Old Dec 14, 2010 | 04:26 PM
DNS711's Avatar
Default ESP BAS warning
After some hard wheeling my ESP, BAS, and loss of traction lights came on and the steering wheel was off center.
This happens a lot after I wheel the Jeep hard, and all I usually have to do is re-center the steering wheel. I re-centered the steering wheel, but the warnings are still there. I connected my Superchips tuner and tried to clear the codes, but this did not help either.
Any suggestions?
Old Dec 14, 2010 | 05:16 PM
dirtyboyjustin's Avatar
is the abs light on too or just the ones you mentioned, mine had all abs, loss of trac, bas/esp lit up the cruise control did not work this was all due to a bad wheel sensor which once fixed solved all the lights and cruise
Old Dec 14, 2010 | 05:20 PM
Ggray's Avatar
When it happened to me, I needed a front wheel alignment and that fixed it.
Old Dec 14, 2010 | 06:08 PM
aermotor's Avatar
If you wheel is ever not centered those lights will more than likely always trigger. Best to use a 15mm wrench and adjust your drag link to get it back closer to normal when done wheeling.
Old Dec 14, 2010 | 06:48 PM
Rafi's Avatar
i had those lights turn on and turn off by themselves the other week.
i have no idea what it was. wasn't after a wheeling event. it was actually on the way to one. but turned off before i got to the trail.
could it be flexing too much and tugging on the abs sensors on the front wheels?
Old Dec 20, 2010 | 01:11 PM
danmojo82's Avatar
Mine Just came on today too while I was driving home from having a tire air leak checked out. I did some light wheeling yesterday but it was fine all day afterwards. The lights didnt come on until I was driving it for about an hour today. It was only the ESP BAS light and the ESP/TCS Indicator light that came on. Im heading to the dealer tomorrow so hopefully it wont be anything too serious. I havent seen anybody say that their engine fell out when the light came on so far. So i think im good
Old Dec 20, 2010 | 01:27 PM
mediocre69's Avatar
If you had to re-center your steering wheel after wheeling then you bent something. Either the tie rod or drag link. Check your toe-in to see if you bent the tie rod. Once it is bent it will bend more very easily.
