ESP intermittently activates when I turn right
Old Oct 9, 2010 | 07:58 AM
pablocabo's Avatar
Default ESP intermittently activates when I turn right
Name:	Jeep at the lake.jpg
I lifted my 2007 Sahara JK with a Rubicon Express 2" Budget Boost with Monotube Shock.
Ever since then, when I turn right going about 30mph... (turning from one road to another), my ESP activates! Scares the hell out of you at first... because it changes the power, brakes, etc...
I've taken it to the dealer (said there's no problem), taken it to the people who installed it (said there's no problem), and other independent dealers... all say (there's no problem).
BUT... damn thing keeps activating when I turn right (so there is a problem). Only thing I can think of is the turn's momentum (minimal G Force) activates the ESP in thinking possible roll-over.
Has anyone had this experience... and been able to solve it?????
THANKS!!!
Old Oct 9, 2010 | 08:09 AM
geebee's Avatar
Originally Posted by pablocabo
Attachment 94113Hey all...
THANKS!!!
did you re-align your front end after the lift ??? what is your toe-in ???
Old Oct 9, 2010 | 08:13 AM
geebee's Avatar
is your steering wheel straight ?? have your tires been properly rotated (not wearing funny) ??
Old Oct 9, 2010 | 08:22 AM
Dozilla's Avatar
I had this problem too but it only did it at this one turn and if you went around it to fast it would activate the ESP. I solved the problem by disabling the ESP with my SuperChips.
Old Oct 9, 2010 | 09:02 AM
SoupSandwich's Avatar
Check to see if your steering wheel is centered. It may be off by a little bit. Drive completely straight and stop your Jeep and look at the steering wheel. If it seems a bit off you can adjust it easily to get it right on.
Here is a good how to guide.
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Oct 9, 2010 | 09:46 AM
Northern Wrangler's Avatar
THANKS!!!
I would recommend picking up an AEV procal. Its great for reprogramming change in tire size etc and it also has the option to perfectly recenter your steering wheel. I just plugged mine in when my tech was doing the alignment after my lift install. I sat in the Jeep and told him when the wheel was center based on the indication made by the procal and he tightened everything up. I've yet to have any issues (except when I bent my tie rod).
Also I would recommend you thoroughly read the FAQ section as it covers a ton of the issues seen after installing a lift etc. Plus you'll learn a ton!
Old Oct 9, 2010 | 11:13 AM
sshifflett's Avatar
THANKS!!!
The same thing was happening to me for 5 months. I got front adj. lca's to adjust the caster. no more esp problems since.
Old Oct 9, 2010 | 11:29 AM
ArmedSuspect's Avatar
take the advice and have the issue fixed correctly first... then put in a switch to completely turn it off when you want.
Old Oct 11, 2010 | 07:04 AM
pablocabo's Avatar
thanks for responding... didn't align front end or change toe-in because I was told that <3" lift didn't require it with the new JK's.
tires are wearing even...
think i'm going to investigate the straight steering wheel issue first.
