ESP on a lifted rig - tips
Old May 22, 2009 | 08:40 AM
brandonbooth's Avatar
the ESP is worthless... just dissable it... mine has been ever since I got my lift you get used to the light being on and i dont even hear the ding sound anymore when I start up my rig
Old May 22, 2009 | 10:29 AM
SilverX's Avatar
ESP sure isn't worthless when you live North of the border, lol... with a 2-foot snowfall, ESP suddenly becomes your best friend.
I will do whatever I can, with modifications, to keep the ESP on my X working properly. Does anyone foresee any problems if I go as much as 2.5" of lift? Is the caster adjustable stock? I didn't think it was.
On a side note.. I picked up the may edition of JP magazine and it actually has a kickass write up in it regarding each stage of ESP, what it does, and how to disable it in increments. Way easier to understand and much more fun to read than what's given to you in your owner's manual. Also shows you what is disabled and what is still working on each stage! Really cool... if you're a geeky gearhead like myself.
Old May 22, 2009 | 10:38 AM
Piginajeep's Avatar
You'll be fine, If people are having issues with ESP after the lift, its because they have not dialed in the lift correctly...
I love the esp system
Old May 22, 2009 | 10:51 AM
Doc_D's Avatar
What he said.
Old May 22, 2009 | 11:07 AM
tomharley's Avatar
Originally Posted by Doc_D
I went through and fine tuned my suspension. When I first put the lift no I got a lot of ESP firing. Now that I have it all dialed it it's as good as stock (i.e. never fires under normal driving).
I learned a couple things that I thought I would share.
It seems like there only needs to be a few degrees of difference between the steering angle and the vehicle direction to cause ESP to fire. My guess is between 5 and 10 degrees. ESP is MUCH more likely to fire when it senses oversteer as opposed to understeer. This is actually helpful for figuring out if your steering is slightly off, which way it's off.
If your ESP only fires in right handers you steering wheel is probably slightly to far to the left. If your ESP only fires in left handers your steering wheel is probably slightly too far to the right.
Getting the caster right made a big difference. I had very little caster originally. Even though my steering wheel was completely centered I was still getting ESP firing. I believe this is because there is some inherrent slop in the steering. When there isn't enough caster to always want to return the steering to center the wheels and steering wheel flop around in that slop. That can cause the 5 - 10 degrees in difference between the steering angle and vehicle path causing the ESP to fire.
I dialed 6 degrees of caster into my driver's side and 7 degrees into the passenger side. Now the ESP never fires and the jeep drives REALLY nicely. I might still try to add 1/16" of toe-in (for a total of 1/8") just for giggles.
That´s exactly,what I ´ve found on my JK.
Old May 22, 2009 | 09:29 PM
MD5's Avatar
MD5
Some of you set caster angle to 6 degrees driver and 7 degrees passenger.
Why 1 degree of difference ?
Old May 22, 2009 | 09:54 PM
mkjeep's Avatar
My esp issues went away quickly after I installed adj frt lowers. Got the castor set and I find myself trying to push it in those clover leaf turns of the interstate to try to make it go off. Before it went off just as soon as I turned into one.
Old May 23, 2009 | 12:16 PM
Doc_D's Avatar
Teraflex recommends slightly more length on the lower passenger control arm to counteract the tendancy the JK has to pull right. That results in slightly more caster on that side.
Old May 23, 2009 | 12:45 PM
bigbluejk's Avatar
i set mine that way, it no longer pulls to the right ever... even under the heviest braking.
Old May 23, 2009 | 09:04 PM
MD5's Avatar
MD5
Wich is the lenght difference between arms to obtain 1 degree difference ?
