ESP question
Old Aug 24, 2011 | 05:53 PM
robcat33's Avatar
Default ESP question
New to the forum, already learning a ton just lurking around. I do have a question that I haven't been able to find an answer right on point in the forums, so here it goes:
I have a set of Rubicon takeoff wheels/tires on the way that I will use to replace my stock 16" wheels for my new sport. Besides the speedometer/odometer being a percentage off, what else do I have to worry about if it takes me a little while to get the truck to the dealer for the flash. For example, what would the size discrepancy do to the electronic stability control?
Thanks
Old Aug 24, 2011 | 06:00 PM
matt852's Avatar
Thanks
Um all I know is that if you do the 5 sec press of the ESP the ESP will kick on after a so many mph.
Old Aug 24, 2011 | 07:20 PM
BJeepJK's Avatar
I started off with the stock 16's on my X then moved up to the stock 17's off a rubicon and didn't have issues with the ESP, speedo was about 5mph off. I didn't have any ESP problems until after I put on the 2.5" lift with 16 procomp wheels and 33" tires.
Hope this helped.
Old Aug 24, 2011 | 07:36 PM
robcat33's Avatar
OK great, that does help. Thank you guys!
