EVO 44 Magnum sealed axle sleeves
Old 03-26-2015, 05:55 PM
lvd76's Avatar
Default EVO 44 Magnum sealed axle sleeves
I'm looking for some feedback on these axle sleeves. I really like that they are sealed and greasable, but I haven't heard to much as far as reviews. Does anyone know if they can accept a 35 spline chromoly axle shaft?
Old 03-26-2015, 06:24 PM
Invest2m4's Avatar
Hammer-in Nitros are the only sleeves that you can run a 35 spline shaft with. That said, you don't need a 35 spline shaft on a stock JK axle. You can blow your ring and pinion with a 30 spline RCV shaft.
As for the sleeves, weld-in is weld-in. It is just cut to length DOM tubing. Sort of a rip off when you realize how much you are paying for some tube.
Old 03-27-2015, 04:39 AM
lvd76's Avatar
I figured there wasn't too much difference with the different weld ins. These were the only ones that were sealed and greasable, so I was wondering if they were worth the extra $.
Thanks for the feedback.
Quick Reply: EVO 44 Magnum sealed axle sleeves
