Evo adj lower control arms help
Originally Posted by Huggerls1
Yeah they were backwards. Fixed easily. If you could take a look at my other thread about rear swaybar endlinks though I think I'm missing some hardware.
I see you have a 2012 4 door. I'd recommend moving your evap skid over an inch or two before you flex this kit out. Otherwise you might end up tearing your rear DS boot. Also consider longer brake lines. Good luck!
Cool! Glad that worked. I replied to your other thread. Looks like Chris will help you out.
Thanks for your help and input. Look for a thread With me showing off my new set up.
unbolt the brakeline brackets from the shock mount. You have a ton of line left over. You will need to remove the bracket off the line itself.
