EVO bolt on "D" Ring mounts?
Old Apr 1, 2013 | 01:18 PM
maine07jk's Avatar
Default EVO bolt on "D" Ring mounts?
So I went bumperless in the rear and ordered the EVO Bolt on "D" ring mounts that fit in the frame on the rear of the JK. I have been reading posts here and there and it seems that the theme has been they they don't fit right out of the box.
With that said, I got mine today and found just that. As you can see below the frame pieces overlap. I would say who ever measured for the block on the d ring mount did not take into account this overlap. Why not??? I am no fabricator and could see it in two seconds and it doesn't seem to be an error with just mine. I was just hoping to have a quick install, but it seems that won't be the case.
Old Apr 1, 2013 | 01:29 PM
afpilot82's Avatar
JK-Forum Ambassador
That sucks, mine fit perfectly. Maybe they've changed something in the past 6 months.
Old Apr 1, 2013 | 02:17 PM
smittycm's Avatar
Veteran: Marine Corp
I just installed mine less than two months ago and they fit perfectly. That sucks the op is having trouble. Never seen this issue before. Only issue I read about was how they don't sit flush with the end of the frame rail, which isn't an issue for me. I don't mind them being a little recessed.
Old Apr 1, 2013 | 02:20 PM
sick jk's Avatar
My mounts fit good. I trimmed the frame back a little so they fit flush.
Old Apr 1, 2013 | 02:30 PM
OH9JK's Avatar
JK-Forum Ambassador
As far as I know the rear frame rails have always had that overlap...
2008
2009
2011
2012
Old Apr 1, 2013 | 03:55 PM
maine07jk's Avatar
WTF is goin on here. Here is the picture from the EVO web site.
Looks like they sit flush don't they??????? Now I find out after grinding the shit out of them to get them to fit in the tube, that they don't sit flush and I have to trim 1/2" off the frame if I want them too!! They recess inside the frame tube. Glad they mentioned it on their web site.
Old Apr 1, 2013 | 04:22 PM
J.cyr8's Avatar
That's not an EVO issue, unfortunately that's a Jeep issue. Not all frame ends are the same length. I know plenty of people who have had to trim their frame back a half inch or so to make them sit flush. Some even had to do so, that way the d rings could move freely. Unfortunately that's just a small hiccup to go through to get these on. Im picking mine up tomorrow, an I'm praying I won't have to trim. But nothing that 15 mins with a sawzall can't fix!!
Old Apr 1, 2013 | 04:59 PM
Nibsirb's Avatar
Mine installed pretty damn easily. As far as the trimming....do it or dont. I didnt trim mine at all and they work just fine for me
Old Apr 1, 2013 | 05:21 PM
maine07jk's Avatar
I understand I can either trim it or not. Point is they don't fit for crap and I shouldn't have to trim anything. Nor did I want to trim my frame. Thought they would fit flush from the start.
Old Apr 1, 2013 | 05:35 PM
J.cyr8's Avatar
I understand, but that's not evo's fault....that's what happens when you have different assembly lines for jeeps. The ones coming out of one build center might be a bit longer than ones that come off the assembly line across the country. Modding never comes easy....just do what you have to do
