EVO Coil over and ABS sensor
Old Jan 27, 2009 | 01:13 AM
JK07's Avatar
Default EVO Coil over and ABS sensor
The stock ABS sensor wire is too short even for good flex suspension. Wondering if EVO has any extended ABS wires for the coil over conversion?
Old Jan 27, 2009 | 01:27 AM
Ctimrun's Avatar
The stock ABS/ESP wires are plenty long for even the 14" travel coilovers from EVO. They just need to be disconnected from their mounting points farther up the wire. Off Road Evolution remounted the wires at different point to keep them from getting tangled in the suspension parts. The only picture I have doesn't show it very well, but if you look closely in the picture near the bottom portion of the coilover spring, you will see the ABS/ESP wire. It is tie wrapped to the coil spring right there to keep it from pulling out of the brake assembly. They also reconnected it up near the frame as well, but I don't have any photos of that.
Old Jan 27, 2009 | 02:42 AM
JK07's Avatar
Awesome Ctimrun
