Evo Coilover questions
Old Aug 18, 2016 | 02:46 PM
kjeeper10's Avatar
Vet Army
Why raise the lower then ?
Old Aug 18, 2016 | 03:41 PM
mdash's Avatar
Raising the lower mount would make it worse. Is that what you're asking?
Old Aug 18, 2016 | 04:19 PM
kjeeper10's Avatar
Vet Army
No the evo Rock Stars leave if stock.
Old Aug 18, 2016 | 04:46 PM
Jonathan_JK's Avatar
Looks like he's running stock poly bump stops. You could get some king bump stops to help with bottoming the shocks out.
Question though are you actually bottoming out the shock or are you hitting the frame with the axle? Coil overs have a lot of travel my guess is you have too much travel for the amount of lift you have.
Old Aug 18, 2016 | 05:10 PM
ronin2120's Avatar
Vet Army
I thought the evo rock stars raise the lower mount 1.5"
Old Aug 18, 2016 | 05:53 PM
Biginboca's Avatar
That's correct
Old Aug 18, 2016 | 06:52 PM
mdash's Avatar
The Evo rock Stars raise the lower mount 1.5" so by him doing that he made his problem worse. Raising the upper mount would get him back to stock type lengths.
Old Aug 18, 2016 | 07:44 PM
twinz33's Avatar
Just to add some info on the EVO bolt ons, the fronts are 12in coilovers and the rears are 10in
I found mine to work best at 5in of lift, a good balance for my 40x1550s
Photo is at 5in of lift
Old Aug 19, 2016 | 12:27 AM
Extremneon's Avatar
I have the same setup and have been looking at this lately. I noticed my jeep was sitting little lower in the back, so I increased the preload to 1.5" in the rear. Has leveled it back out, but next I think I need to look at the psi in the shocks or heavier springs.
Will any nitrogen fill shop be able to look at the psi and fill?
Old Aug 19, 2016 | 12:59 AM
kjeeper10's Avatar
Vet Army
Yep thats my point. If the EVO bolt on kit has a issue with up travel why raise the mounts.
