EVO Double ThrowDown vs. MetalCloak 6Pak
I'm having hard time trying to decide on what system to use and I would like to know you guys opinion on this. Anyone have any experience (maintenance, ride comfort and performance) using both or one of the other? Please post your thoughts on this.
Thanks |
From my original response to your question in another thread:
Originally Posted by JKred
(Post 3574302)
The DTD is a cantilever rear, standard over axle front coilover/bypass shock system that is really most beneficial desert racing and high speed.
The 6pak shock is a floating body dual piston internal bypass shock designed to give exceptional overall travel out of standard coil/shock brackets. Significantly less evasive install. Apples compared to marinated steak tips. |
(Post 3575964)
You need to ask yourself what your intensions are with your jeep before you settle on a kit Performance? We race King of the Hammers with our double throw down system. The currie johnny Joints will need maintenance on oil changes (grease into the fittings). |
Thanks for the info guys.
| All times are GMT -8. The time now is 03:06 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
