EVO Gusset install question
For those of you that have installed the EVO Gussets, did you remove the ball joints or weld a small amount, cool the weld. Then move to the next gusset and repeat until finished? Part two to the same topic. Did you stick weld or wire feed? Thanks in advance.
I spent about 1 hour welding each side. 1 1/2" welds, followed by wet rags. I have had no problems yet in the 3k miles that they have been on. I used a Lincoln wire feed.
